You don't mention if you just added all the fuel system upgrades or if it was running fine prior to adding the gauge. Either way, your wording leads me to believe you may have installed the fuel pressure gauge in the wrong spot, or plumbed the fuel system incorrectly. The regulator maintains upstream pressure by bleeding off excess. Therefore, your plumbing should be: Pump Filter Pulse Dampener (if installed) Gauge Fuel Rail Pressure Regulator Return to tank If it is plumbed how it sounds (Pump, filter, FPR, Gauge, fuel rail, return) then you are not getting fuel pressure to your injectors. Black smoke is excess fuel. If you just installed the injectors perhaps pinched injector oring is leaking fuel into some cylinders?
------------------------------------------------------------------ 1992 300ZX NA 5 Sp (Dead) 1990 300ZX NA Auto 2+2 (Dead) 1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP) 1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP) 2004 G35 Sport 6MT (DD) 2008 Honda Civic (DD) 2014 Nissan Murano (DD) 1969 Chevy C10 (Toy) 1969 Chevelle (Toy) |
